2006 883 sportster, here's the problem, twice now while make a slow left hand turn from a stop engine cuts off and stalls lights stay on. key has to be turned into off position and then back on and bike starts again, wire connections seem to be solid, engine both times were warm and operating fine for miles before occuring, any ideas? any help or ideas is appreciated
I think the lean kill switch goes at 45 degrees. If it was just a normal stall you shouldn't need to turn the key off and on. Maybe possible the lean switch is out of whack?
The bank angle sensor is part of the TSM/TSSM. On the Sporty, it shuts off the bike if the lean angle is over 45* for a certain amount of time (1 sec I think).
