Passenger pegs won't stay up
Old 08-12-2008 | 12:26 PM
Romark's Avatar
Romark
Default Passenger pegs won't stay up
After changing my pegs to the HD Airfoil ones, my passenger pegs won't stay up. The bolts I used are the the ones that have a threaded sleeve with the bold threading into the sleeve. I believe that the bolts are a HD part. I reused the spring steel looking D shaped spacer.
Any advice on how I can fix this and keep my pegs up?
Thanks,
Mark
Old 08-12-2008 | 12:29 PM
ken thompson's Avatar
ken thompson
The Schlong Man
Take that D shaped thing, bend it a little, and stick it back in there. Worked for me.
Old 08-12-2008 | 12:34 PM
Uncle Scrooge's Avatar
Uncle Scrooge
Viagra, but if they stay up more than 4 hours call your mechanic.
Old 08-12-2008 | 12:35 PM
krub6t9's Avatar
krub6t9
buy new spring clips its what I had to do
Old 08-12-2008 | 12:41 PM
cHarley's Avatar
cHarley
+1 - I had the same problem and was going to replace all the spring steel things on my pegs. That was until I found out how proud HD is of those nothing, unfinished, pieces of dung. $3.00 ea. is pretty steep for someting not worth more than 5 cents.
Old 08-12-2008 | 12:43 PM
Romark's Avatar
Romark
And does it matter which side the D shaped spring goes on?
Old 08-12-2008 | 12:54 PM
cray49a's Avatar
cray49a
Put on one more D washer.
Old 08-12-2008 | 01:02 PM
White-Trash's Avatar
White-Trash
Welding torch?
Old 08-12-2008 | 01:05 PM
djvargas's Avatar
djvargas
agree, a little curve right down the middle.
Old 08-12-2008 | 01:09 PM
ChefE's Avatar
ChefE
I did the same thing and have had no more probles with the pegs staying up.
The spring thing is on the underside of the pegs on mine.
Quick Reply: Passenger pegs won't stay up
