polishing aluminum cases
Old 08-10-2008 | 08:17 AM
QWeeks's Avatar
QWeeks
Default polishing ca
i havent had time to get supplys yet but i noticed what looked like thin plastic on a pipe.the only thing i had was acrysol and it worked like a champ.
Old 08-10-2008 | 08:52 AM
junkorgem's Avatar
junkorgem
Default Polishing Aluminum
I have been polishing as a hobby for at least a few years and have made my share of errors. Caswell Plating has supplies and a Polish/Plate/Powdercoat forum that is really useful. Back to your original question, if the engine cases on your bike are powdercoated you could strip with aircraft paint remover.(You will want the cases removed from the bike, of coarse) The next step would either be sanding or greaseless compound. Then go with brown compound and then white, finish with white rouge, or mothers or similiar. www.caswellplating.com has an online store where you could buy an aluminum polishing kit for pretty reasonable. Their forum can be searched to solve any problem you could have. Good luck.
Old 08-10-2008 | 08:56 AM
PastorTom's Avatar
PastorTom
Originally Posted by Just Dave
Hey Pastor Tom, Can you tell me a name that might be on the Liquid Deoxidizers? I sure need some of that for my sporty. I have heard that you can use Aircraft Stripper to cut the clear coat off, Is that what the Deoxiders do? TIA.
Lemme look when I get home, I think I have a bottle in the shop..
ccstarnes7
01-31-2013 07:06 AM
HDexplorer
02-24-2012 04:18 PM
Shorty00645
11-21-2011 02:04 PM
08fxstb
01-02-2008 06:19 AM
Marsh
09-22-2007 01:50 PM
Quick Reply: polishing aluminum cases
