Oil From & through the air cleaner
Old 07-31-2008, 11:03 PM
lee123's Avatar
lee123
lee123 is offline
Default Oil From & through the air cleaner
Not uncommon I know,&nbsp\\; but mine just started.&nbsp\\; Why ?&nbsp\\; And More importantly - what to do about it.&nbsp\\; Seems to be most if going up hills, under load, I thnk.&nbsp\\;
Old 07-31-2008, 11:29 PM
Other Sheep's Avatar
Other Sheep
Other Sheep is offline
Default RE: Oil From & through the air cleaner
Most common reason, too much oil. 2nd most common, hard throttle, high rpms. Its made that way, nothings broken.
Old 07-31-2008, 11:30 PM
Other Sheep
Dont overfill oil tank. Ride it hard and clean the oil when done having fun.
Old 07-31-2008, 11:31 PM
Other Sheep
Breathers for the cylinders route throught the air filter.
Old 08-01-2008, 04:08 AM
mchildree's Avatar
mchildree
mchildree is offline
Me and several other HD owners have to wear khaki slacks to work.&nbsp\\; We consider the oil spots under the right leg as badges of honor.
Old 08-01-2008, 04:29 AM
JBaker421's Avatar
JBaker421
JBaker421 is offline
Big Kahuna HDF Member
What engine do you have? My evos will do that but Ive never had it with a twin cam. On the evos I finally gave up and routed that hose down under the frame, but safely off to the side so it wouldn't get oil on the rear tire.
Old 08-01-2008, 06:37 AM
oldairboater's Avatar
oldairboater
oldairboater is offline
My twin cam will do it but not my evo. If I run the twin cam hard for awhile it will do it. There are several different ways to solve the problem and a few that claim to fix it. JBakers is the easiest and fastest way. There are a few oil mist separation systems that claim to work.
Old 08-01-2008, 07:11 AM
cHarley's Avatar
cHarley
cHarley is offline
Install a bypass system, problem solved. Oil doesnt belong in the air/fuel mix anyway.
Old 08-01-2008, 07:23 AM
ladodgerdog's Avatar
ladodgerdog
ladodgerdog is offline
cHarley, what does the end look like?
Old 08-01-2008, 08:03 AM
Mr. Lucky's Avatar
Mr. Lucky
Mr. Lucky is offline
ORIGINAL: cHarley
I was thinking of doing this, but re-using the charcoal canister that comes on California bikes for the purpose. Anyone done it or know if there are problems in doing so?
Quick Reply: Oil From & through the air cleaner
