Snap on Torx set...should I?
RE: Snap on Torx set...should I?
To get the link to work, cut and paste it in a new window.
Edit out each (backslash backslash semi colon) which appears after each (ampersand).
Hit enter.
Hit enter.
The tamper proof bit has a hole in the end to mach a pin in the center of the torx screw/bolt.
Just a little deterent. \\;
http://www.mcmaster.com/nav/framewor...%2bTorx%2bKeys
Not that the link will work but there is a picture there.
Some tools I've found are better not to scimp on. Torx, 12 point sockets are just a couple. Cheaper ones aren't sized right, can round off, don't grip well and can ruin a bolt, nut, or screw head. You spend more time fighting with it than if you had a qaulity peice, JMHO.
Funny you should ask xcelr8, just bought a T40 to break loose the bolts holding the front disc.Grabbed and turned them right out.Twisted the T40 off out of the no names I got off ebay cheap.Gonna get the entire Craftsman 3/8" dr set now, think they were $39 at Sears.
