Rear flat fix on Rocker expensive
Got a nail in my brand new Rocker rear tire. They are expensive to fix! Now I have a mark on my nice rear wheel.[:@]Plus it cost $315!
RE: Rear flat fix on Rocker expensive
I just got a screw in my rear tire on my cross bones, cost 107 bucks to repair at the dealer, but since \\;it has a \\;tube with the spoke rims I didnt have to worry about the tire itself, plus the dealer picked up the bike from the house. \\;
I think that we as motorcycle riders take a beating on tire prices. I know that a motorcycle tire supposedly has been really engineered to make it the best but its just a tire. I pay as much or more for a motorcycle tire and it is a third of the tire I run on my truck. Another gripe is the charge for shop labor to mount and balance a tire. I ended up finding a cheaper route to go. I use an Indy.
Well, I was up there on the bike and my chrome debris deflector was in , so I said might as well put in on while you have the bike.
i`ve been preaching indys for yrs, they are all mostly ex-dealer mech, who just went into bus themselves i just had front and rear tires replaced with metz, and it was a 150 difference
Dealer charged me $50.00 labor to mount and balance new tire which I purchased from the dealer. A few weeks later hit a pothole from hell and lost the stick on weights. \\; Dealer was busy and would try to work it in Sat. morn. \\; Indy told me to bring it in and would jump right on it. \\; Removed tire and balanced tire to tune of $100.00 labor.[:@] \\;
Let's see, $50.00 to mount and balance dealer...Indy twice as much to balance only.
Wife's Deluxe needed new tire, tube and rim band...$75.00 labor dealer...
wow i charge 35 to mount an balance... your indy is nuts! HD wants 75 a tire... order your tires online take the wheel off and bring it in... easy. \\; if you can not pull your own wheel off you should not be riding
ORIGINAL: JRK5892
wow i charge 35 to mount an balance... your indy is nuts! HD wants 75 a tire... order your tires online take the wheel off and bring it in... easy. \\;\\\\\\; if you can not pull your own wheel off you should not be riding
ORIGINAL: JRK5892
wow i charge 35 to mount an balance... your indy is nuts! HD wants 75 a tire... order your tires online take the wheel off and bring it in... easy. \\;\\\\\\;\\\\\\\\\\\\\\; if you can not pull your own wheel off you should not be riding
Sure, I will tell my 71 year old neighbor that if he can't pull the wheel, he should just \\;\\\\\\;quit riding.
If you can't take your computer apart, you shouldn't be \\;\\\\\\;online \\;\\\\\\;
ORIGINAL: JRK5892
wow i charge 35 to mount an balance... your indy is nuts! HD wants 75 a tire... order your tires online take the wheel off and bring it in... easy. \\\\\\; if you can not pull your own wheel off you should not be riding
