Shifting Gears
Old 07-15-2008, 11:18 PM
Cue's Avatar
Cue
Cue is offline
Default Shifting Gears
When shifting gears on a heel toe shifter is it alright to keep the shift lever down until next gear?&nbsp\\; So I push the lever down with my heel, hold the lever down until next gear when I lift up, clutch, press lever down and hold.&nbsp\\; Sorry for the odd question, Just making sure I am not hurting anything
Thanks Cue
Old 07-16-2008, 12:01 AM
SecretAgent's Avatar
SecretAgent
SecretAgent is offline
Default RE: Shifting Gears
DON'T DO IT.&nbsp\\; you're doing all kinds of bad things to the tranny and synchros when you do that.&nbsp\\;
Old 07-16-2008, 12:21 AM
ebeattie's Avatar
ebeattie
ebeattie is offline
The heel toe shifter is nothing more than an extended shift lever shaft with a rear "heel" lever bolted on. No reason to shift in such a manner as your doing IMO. Shift and release.&nbsp\\;
Old 07-16-2008, 04:21 AM
Capt.Bob's Avatar
Capt.Bob
Capt.Bob is offline
This question begs to be asked. WHY?
Old 07-16-2008, 05:42 AM
dog155's Avatar
dog155
dog155 is offline
You are not doing any damage to the trans,but it seems like a very poor habit.I never hurts to ask a question!
Old 07-16-2008, 05:43 AM
deadman77's Avatar
deadman77
deadman77 is offline
Why would you want to hold it down? It has to come back up to shift the next gear.
Cant be good for anything.
MikeM
Old 07-16-2008, 08:52 AM
Cue's Avatar
Cue
Cue is offline
It is a uncomfortable position for me to keep my heel in a "up" position waiting to press down for the next gear. (I do a lot of city driving)\\\\\\; And it doesnt work out to push the lever down, rest foot on footboard, push lever down again, and repeat.&nbsp\\;\\\\\\; It's just easier to push the lever down keep it there, and then a quick up and down action to shift until next gear.&nbsp\\;\\\\\\; Once I am through all the gears I will need, then I move my foot to the footboard.&nbsp\\;\\\\\\; The gears always shift fine, nothing different noticible. This is the first I have ever used a heel toe shifter and I did not think it was "rocket science".&nbsp\\;\\\\\\; Maybe I am using it wrong and it should not be uncomfortable.&nbsp\\;\\\\\\; I do tend to over complicate things on a regular basis.
Thanks Cue
Old 07-16-2008, 09:20 AM
oldairboater's Avatar
oldairboater
oldairboater is offline
Put you foot back on the floorboard after shifting. Repeat process as needed. It's not good to keep weight on any levers as a habit of resting. Be it shifter, clutch or brakes. Key word is weight. Its okay to cover pedals or shifters and levers but not to rest weight on them. Premature wear and stress for no reason but fear or comfort.
Old 07-16-2008, 09:32 AM
07SG's Avatar
07SG
07SG is offline
Cue,
I know what you mean about the uncomfortable foot position. I overcame this by simply repositioning the heel shifter a bit lower. It is a simple procedure.
Someone mentioned synchro damage. I was under the impression that the HD tranny doesn't have synchros. ??
Old 07-16-2008, 12:37 PM
wallyn's Avatar
wallyn
wallyn is offline
You can always use the Toe shifter in heavy Traffic. I will do this when I am shifting a lot up and down.
It says somewhere in the manual not to have constant pressure on the shift lever.
I lowered my heel shifter so it is at the minimum spec in relation to the floorboard. So I do not have to lift up my heel as far.
Quick Reply: Shifting Gears
