oil sumping
RE: oil sumping
Off the top of my head, check valve if engine does it after sitting awhile. Scavenging by the oil pump if running. Some others might have better answers.
RE: oil sumping
Yep, since your oil bag is higher than your pump, they have a check valve between them. \\; If you haven't started the bike, the oil seeps past that check valve. \\; Don't be suprised that when you do start it, since the pump won't be able to handle the excess oil, that a bunch doesn't puke out all over your leg.
Respects,
Ed
Respects,
Ed
