road king running terrible
Old 07-01-2008, 05:35 PM
mongo rdkng's Avatar
mongo rdkng
mongo rdkng is offline
Stage I
Default road king running terrible
I have a 01 roadking police model,stock except for arlen ness big sucker air cleaner. Riding to work the bike started skipping not too bad but noticable,going home ran fine,,stopped at store and when I left started skipping again intermittently but getting worse as i rode.The bike is not rideable now due to the problem getting worse each time I ride and the engine light comes on and is staying on longer.Bike acts like it is running out of gas,thats all I can think of for now any ideas wold be appreciated. Oh yeah its fuel injected and has a little over 37000 miles.
Old 07-01-2008, 06:00 PM
Domestic Violence's Avatar
Domestic Violence
Domestic Violence is offline
Default RE: road king running terrible
check all grounds and battery connections
Old 07-02-2008, 10:22 AM
irishviking's Avatar
irishviking
irishviking is offline
I have the same bike.&nbsp\\; I had to install a Power Commander III USB.&nbsp\\; Then have it dynoed.&nbsp\\; Depending on the set up I have to assume its running too lean.&nbsp\\; I had all the same symptoms.&nbsp\\; My bike has alot of engine work done and the stock fuel management system could not keep up with demand.&nbsp\\; The bike has run great since the PCIII installation.&nbsp\\; My 2 cents..
Old 07-02-2008, 10:30 AM
casique's Avatar
casique
casique is offline
Check the plugs!
Old 07-02-2008, 10:54 AM
ken thompson's Avatar
ken thompson
ken thompson is offline
The Schlong Man
Most likely one of three things:&nbsp\\; fuel, air or spark
Old 07-02-2008, 12:24 PM
richbiker's Avatar
richbiker
richbiker is offline
6th Gear
It could be a intake gasket leak. My friends E-glide std socked in the front gasket at about 40k.
Old 07-02-2008, 12:45 PM
Matrix's Avatar
Matrix
Matrix is offline
Try checking the battery cables and make sure that it isn't grounding out on anything inside the. This happend to me a while back and this was my problem.
Old 07-02-2008, 02:37 PM
Medicfrost's Avatar
Medicfrost
Medicfrost is offline
I&nbsp\\;had a&nbsp\\;similar problem on my 2002 FLHP-I.&nbsp\\; Mine ended up being a sensor going bad in the front cylinder.&nbsp\\;5 visits to the dealer, and only a mechanic on the 5th visit, who also had a similar bike, realized what it was.&nbsp\\;I'm not saying that that is the problem with your bike, but it's an easy thing to check.
All you need to do is pull back the rubber boot, and disconnect the cord. &nbsp\\;The sensor is about $40, and comes out with a socket. It took me about&nbsp\\;6 minutes to change it out.
&nbsp\\;
&nbsp\\;
Old 07-02-2008, 04:34 PM
krusr's Avatar
krusr
krusr is offline
KT pretty much summed it up.
Fuel, air or spark.
If your engine light is comming on longer, you've got a code error.
If it were me, I'd pull the rear plug and take a look, sounds like it's fattening up for some reason and that will tell you in a hurry.
Any recent changes that may have changed the AFR?
Air cleaner, pipes, was it hosed down with detailer and maybe sprayed some close to the air cleaner?
Pull a plug, it might tell you a lot.
Krusr
Old 07-02-2008, 05:10 PM
e6fmf's Avatar
e6fmf
e6fmf is offline
Try some fresh gas from another station.................
Quick Reply: road king running terrible
