road king running terrible
Old 07-02-2008, 05:18 PM
deadman77's Avatar
deadman77
deadman77 is offline
Default RE: road king running terrible
Keep it simple. Check the easy stuff first. Gas in the tank? Fuel pump working? Listen when you turn the key. Air cleaner clogged?
Pull the plugs. No shame in letting the pros check it out if you cant find it.
MikeM
&nbsp\\;
Old 07-02-2008, 06:23 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,808 Likes on 2,544 Posts
&nbsp\\;
&nbsp\\;Could you take it some where to see if any codes have been tripped? Picture shows a cylinder head temp sensor and at the baseof the front cylinder there should be a crank position sensor, this sensor sends a signal as to when the plugs should fire. It senses the teeth on the flywheel and the empty spot where there are no teeth. Also known as the CKP sensor.&nbsp\\;
Swa Man
07-19-2019 04:14 PM
JustDave13
03-28-2016 06:55 AM
creepster
09-10-2014 11:37 AM
sbergerson
07-29-2014 11:22 AM
Warpig
07-22-2007 12:22 PM
Quick Reply: road king running terrible
