Chevron Delo 15 40 Oil
RE: Chevron Delo 15 40 Oil
Harley oil is made by whoever has the cheapest bid when the contract is up.
Nothing wrong with running the diesel oils if you want. I use Royal Purple in my bike and I get better milage and she seems to run better.
I read posts about Oils it all ways seams to go in circles. I use Moble 1 in the Cages HDsyn in the Bikes. Was going try Amsoil in the bikes. and Amsoil gear lube in my Jeep Difs. But they don't sell it around were I live and Im not goimg to waste my time and money driving around for it. Back in the 60's and 70's It all was about Pennsylvania refined Oil's don't read much on that any more.
Be advised that the new Delo 400 \\;\\\\\\;15/40 L.E. [ low \\;\\\\\\;emissions ] \\;\\\\\\;has same additive package but with reduced numbers which is why \\;\\\\\\;I stocked up on the old Delo 400 \\;\\\\\\;15/40 formula. Old formula \\;\\\\\\;[ non L.E. ] is hard to find \\;\\\\\\; as they quit producing it \\;\\\\\\;some \\;\\\\\\; time back. I suspect that \\;\\\\\\; the \\; other \\\\\\;diesel dinos  \\;\\\\\\;have done the same \\;\\\\\\; , Rotella , Delvac.....etc. etc.
note: not saying the new stuff is not any good , just being more specific.
Received 1,296 Likes
ORIGINAL: JBaker421
Citation, please? How does Multigrade SAE 15W-40 not work as other 15W-40 oils? PS I don't want enough polymers in my oil to push it to say 5W-50. \\;\\\\\\;
ORIGINAL: pococj
The only problem with it is that it does not meet the specs on viscosity that HD says during warmer weather.
That fact, in and of itself, can cause a voided warranty if there is an engine whizoo.
As far as the oil additive package, the Delo probably has a better overall package than the standard HD oil, and as good as many other oils.
If you run the summer here in Texas with a 40 weight in your HD you won't like the results long-term.
Noisy will not describe it.
An example-
2007 Sportster owner's manual, page 80.
SAE 10w40 - lowest ambient temperature below 40 F.
SAE 20w50 - lowest ambient above 40 F.
Quoting, The preferred viscosities for the diesel engine oils in descending order are - 20W50, 15W40 and 10W40.
If you run incorrect viscosity for the temperatures you ride in, could you beat their claim of warranty voiding?
Maybe, if you could show the oil did not cause the damage.
But how much would it cost to hire the big guns needed to do that?
And how long would it take, with you being without a bike?
Finally, I do not run HD oil.
I run Mobil 1 15w-50.
But that may soon change as I am getting ready to have a sample tested.
I was not happy with the last sample tested.
If I change it will not be to HD oil.
I refuse on moral grounds to use anything Citgo-related.
ORIGINAL: pococj
Nothing to do with whether it is a multi-grade, but with the 40 viscosity.
An example-
ORIGINAL: JBaker421
Citation, please? How does Multigrade SAE 15W-40 not work as other 15W-40 oils? PS I don't want enough polymers in my oil to push it to say 5W-50. \\;\\\\\\;\\\\\\\\\\\\\\;
ORIGINAL: pococj
An example-
ORIGINAL: JBaker421
Good points but remember Harley knows that the new bikes are running hotter than hell. Everything changes when you do a stage 1 or even if you run an earlier bike. I still don't like the amount of polymers it takes to push oil to 15W-50. I run my bikes a little rich and therefore a little cool. I got 140k miles on an EVO on Delo 10W-40 and never looked back. I'm sure not worried about my stage II twinkies. Imho if your bike is running hot you're ruining it no matter what oil you use.
Both these otherwise excellent oils were not up to the task of 100+ F days.
I could ride to work in the early morning, about 44 miles, average temps about 75 - 80 F, with no problems at all.
I could ride home from work with no problem unless I pushed it up to 80+ for the last leg of 12 miles.
When I went on my usual Saturday rides, normally 200 to 400 miles, at about the 100 mile mark the engine would start acting up, clanking, rattling, etc.
I hit Wally World and grabbed some Super Tech 20W-50 and the problem went away.
My conclusion is that the 40 weight was too thin.
At any rate, I got through the summer on the ol' Sloptail, and then started riding the Nightster while going through the old bike.
If you don't like it just SKIP READING IT... it would be a shame to not learn about the changes going on in two years time and what newer members of the forum think. There nothing wrong with going over new ideas on the same old material... beats the hell out of "what the wife did on her last ride"............IMO
Delo and other oils
Hi This link should shed some in depth light on oils even Delo and the lowest winning bidder who is making H.D. oils last year it was Kendall SoUno...this link will shed all the light youll need to know about oils --->
http://motorcycleinfo.calsci.com/Oils1.html
