Small garage door opener
Old 06-28-2008 | 07:35 AM
lilrooster76's Avatar
lilrooster76
Default RE: Small garage door opener
Craftsman makes a small keychain style one that i use, it's about the same size as my key fob
Old 06-28-2008 | 08:05 AM
barkster99's Avatar
barkster99
I have the HD kit that works by cycling the hi/lo beams.&nbsp\\; About $120 list.&nbsp\\; Kind of pricey for a gd opener but brings a smile to my face everytime I use it.&nbsp\\; Very Slick.
&nbsp\\;
According to above, someone makes something just like it for about $40.&nbsp\\; Let's see, HD $120, someone else $40.&nbsp\\; Yeah, that sounds about right.
Old 06-28-2008 | 08:21 AM
Teagan's Avatar
Teagan
I've got a small Key Fob one from Sears that has a large opener bottom on it.&nbsp\\; It fits into the change pocket on my jeans and I can hit it with my right hand as I'm pulling up or after pulling out.
Old 06-28-2008 | 10:41 AM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
ORIGINAL: Nickpisp
I have this one on my key ring.
I zip-tied one of those to a cable near the clutch lever.
Old 06-28-2008 | 11:12 AM
WS6 Formula's Avatar
WS6 Formula
I got a 12 volt powered remote, took the battery out, soldered in a jumper wire on the remotes switch terminals and soldered wires to the battery tabs in the remote, one too ground and one tapped into the high beam switch wire. This way you use the bikes battery to operate the remote, and you'll never have to replace the remotes battery again.
Old 06-28-2008 | 03:10 PM
FJRHDguy's Avatar
FJRHDguy
Ditto on the sears keychain remote, I switch from Jacket to Jacket depending on what I'm wearing/riding.
Old 06-28-2008 | 05:09 PM
edilgdaor's Avatar
edilgdaor
I just use the regular door opener that clips to a cage sun-visor. I just hang it on the clutch cable when it's not in the Road Glide's 'glove box'.
Old 06-29-2008 | 06:58 AM
Teagan's Avatar
Teagan
Before I picked up the key chain sized opener, I was just pulling the larger visor sized on from my truck and clipping over my belt on the back of my jeans.
Old 06-29-2008 | 08:25 AM
FXWGG's Avatar
FXWGG
Old 06-29-2008 | 11:19 AM
DLW_FLHTC's Avatar
DLW_FLHTC
+1 Works great
Quick Reply: Small garage door opener
