would you trust a helicoil...?
Old 06-28-2008 | 07:24 AM
1flhtk4me's Avatar
1flhtk4me
Default RE: would you trust a helicoil...?
No problem if installed correctly.Just make sure the hole is straight and use a tap guide.
Threaded inserts are used on aircraft,so they must be safe.
Old 06-28-2008 | 07:28 AM
Nitram_b4's Avatar
Nitram_b4
ORIGINAL: third_left_eye
if it is installed correctly, it should be up to the job. We use them all the time at work on our aircraft.
took the words right outa my mouth
Old 06-28-2008 | 07:31 AM
wideopen1967's Avatar
wideopen1967
&nbsp\\;If you have the wall thickness this is the prefererred set up over the slinky type helicoil. You can get these from mcmaster-carr.
&nbsp\\;
&nbsp\\;
Old 06-28-2008 | 07:42 AM
honestbob's Avatar
honestbob
you might want to consider a threaded insert, much stronger then a helicoil, a litter harder to install but much better
Old 06-28-2008 | 08:01 AM
grumpy irish again's Avatar
grumpy irish again
when possibel I prefer to make a insert with a lip installed from the back side
so it can't ever pull out but heli coils have been used for years on almost everything with good results
[IMG]local://upfiles/5757/7E699B9F5E5C417EB1389268090FE865.jpg[/IMG]
Old 06-28-2008 | 08:37 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Thread lock or thread insert = same product/different trade name
Old 06-28-2008 | 09:54 AM
plane's Avatar
plane
Here's the best thread repair I know of:
http://www.timesert.com/
PITA
07-21-2011 01:58 PM
speedjunkie
07-04-2008 08:51 PM
thrillseeker
06-21-2008 08:47 AM
RGreeves
06-19-2008 09:33 PM
YodaddyKeith
06-11-2008 01:02 PM
Quick Reply: would you trust a helicoil...?
