lowering a bagger?
lowering a bagger?
does anyone have any input on lowering an electraglide ? \\;I saw a bunch rear shock relocater kits on ebay claiming to lower up to 3 inches for like 60 bucks anyone ever use these kind of kits ?are there any downfalls so lowering ?
RE: lowering a bagger?
There are a bunch of different lowering kits out there. Just remember, if you use one these lowering blocks, you have eliminated that much from your tire/fender clearance. If you stay with standard shocks, you will hit the tire if you \\; are loaded heavy and don't blow them up good. Been there and done that.
When it comes to lowering a Tourer I'd stick to the HD parts.....we've never had a problem at the shop and lowering the front and rear makes a big difference. It will run you about $400 total to do both, but you'll keep the comfort that you're used to.......imho
Part #'s
54628-06
54631-02B
Part #'s
54628-06
54631-02B
