HELP problem with led running lamps
I am having a problem wiring a Rick Doss LED tail light and signals. I can't get the running lights on the tail light to work properly. First of all I have a badlands load equalizer wired in (had to the signals wouldn't work without it). Tail light running lights and brake light work fine. If I hook up the running lights on the signals they work fine, but if you put on the signal, it just kind of flickers a little, barely noticeable. If I unhook the running light power, the signals work great.
Am I doing something wrong? Has anyone else experienced this? There's a lot of great knowledge in this forum, I hope you can help. Thanks, Brad
RE: HELP problem with led running lamps
ORIGINAL: GlennA
Have you tried removing the Badlands load equalizer? Maybe they won't work in conjunction with each other. \\;\\\\\\; Just a thought.
Without the equalizer the signals just freeze up, won't flash at all.
Pete838
05-11-2012 02:35 PM
