Cruise control
RE: Cruise control
you might look into Kuryakyn's new aftermarket Cruise Control (p/n 6280). Sells for around $200 (less on some reseller sites). Here's a link...
http://www.kuryakyn.com/products.asp...&\\;ci=3578
RE: Cruise control
I was just funnin with you - I agree it would be pretty cool, but not much good here in the UK, or on a SB as I'd need to stop for gas before I'd got the benefit!
RE: Cruise control
I've used the throttle lock. \\; I admit it doesn't accelerate or decelerate, but I found it very adequate on the freeway. \\; Is the cruise worth it over the thumb activated throttle lock?
RE: Cruise control
ORIGINAL: barjbar
I've used the throttle lock. \\;\\\\\\; I admit it doesn't accelerate or decelerate, but I found it very adequate on the freeway. \\;\\\\\\; Is the cruise worth it over the thumb activated throttle lock?
If you're asking for opinions-ABSOLUTELY........
RE: Cruise control
RKRon: Check out http://www.cruisemount.com/
I installed the HD cruise on my softail using this kit, works great.
RE: Cruise control
ORIGINAL: gtnot
Thanks......looks like a nice option..
RE: Cruise control
Yes the cruise control is nice if you have it, it's better to have and not need than to need and not have is my thoughts on cruise control, I do use it quite often.
RE: Cruise control
I've only had my Ultra two days, and it's the first bike I've owned in 20 years that comes with it. \\; Best option I've ever had on a bike, save for the \\;petite blonde French stripper passenger option (available only in Eastern Canada).
Cannon
Cannon
RE: Cruise control
ORIGINAL: Jonny Cannon
I've only had my Ultra two days, and it's the first bike I've owned in 20 years that comes with it. \\;\\\\\\; Best option I've ever had on a bike, save for the \\;\\\\\\;petite blonde French stripper passenger option (available only in Eastern Canada).
Cannon
Cannon
swipter
06-19-2007 10:45 AM
