Gas Pumps - Are we Being Cheated
In my neck of the woods, all gas stations have only one hose on a gas pump. \\; When I select Premium, how much Regular or Mid-Grade am I getting before the Hi-Test starts flowing? \\; I figure the hose, internal pump and feeder line on the gas pump \\;is full of Regular gas (today's prices) when \\; pull up to it and select Premium. \\; How much of this "other" gas am I paying for before the hi-test gas makes it to the nozzle. \\; Not only am I paying about 45 cents too much for the gas, but I only want Premium in my Electra Geezer. \\; I can not find any older pumps with a nozzle for each grade of gasoline. \\; How much are we talking about here. \\; Maybe a gallon? \\; \\; My tank usually only holds about four gallons when I fuel up, so 25% of my fuel is not what I want. \\; \\;I'm probably wrong. \\; I hope so.... \\;
RE: Gas Pumps - Are we Being Cheated
I only use gas stations that still have 3 hoses. \\; I once didn't care, then one day, the local Mobil ran out of Regular and Plus, so everyone was only using Premium. \\; I pumped up, and it was the best my bike ever ran. \\; I couldn't believe the boost in power. \\;
You can always pump a gallon or two on the ground first. That should clear the hose.
So you think that is the only way we are being cheated. Just pumped 6.2 gal. in a 5 gal. can this afternoon for mowing. I only filled the can to the full line. Told the clerk they should check the pump. She said they were just checked that morning. DUH!
I've always wondered that myself. I know of only one station here that has 3 hoses. I like using Sunoco gas simply because it's 94 octane. I know 1 octane isn't chit, but it supports my sport as well...lol. Think I'll run the tank dry and see if I notice a difference with the 3 hose station.
ORIGINAL: satansoft
the amount is minischule, the hose does not hold fluid, as some people seem to think. Dont worry about it. Its not even 1/4 of a litre in the hose.
Nope your wrong the hose does hold fuel, I know because I tested it once, I turned off the pump then squirted another half gallon or so out of the hose, then when I restarded the pump (with the valve closed) the pump ran up a half of a gallon filling the hose back up.
This has bothered me since I got my bike, with only a 3.3 gallon tank I can only put about 2.5 gallons in if the fuel light has just come on, Im pretty sure im running about half and half in my bike and leaving a gallon or so of premimum for the next guy.
We have one station in town with a dedicated premimum hose \\;and even though they have the 10% ethanol crap my bike runns better on that because at least its all premimum. \\;
