TC96 in hot climates??
Hi,
another silly question coming from me. U know I ordered a FXDL to be delivered in Perth Australia.
during the summer months it does tend to get very hot down there. over 35 degrees celcius.
I have heard that a liquid cooled engine such as the revolution engine would be more suitable to such conditions.
What is actually the problem with hot climates and the air-cooed TC96? Does it overheat and stop running? Are they less powerfull in such conditions?
This question might be silly....but I do appreciate any information.
Thank you guys once again for ur help!
Daniel
Daniel
Daniel, I live in south Florida, it is hot here most of the year, between 90 - 100F, think thats around 50 C+/-. I ride in traffic quite a bit, and I mean Miami traffic ( real bad with lots of Dumasses), get the warning light every now and then when I am stopped for a while but I have Mobil 1 V synthetic oil and an oil cooler so I am not worried about engine damage. Remember an air cooled engine needs air to stay cool, so as as you are moving you will be fine. I also ride a KLR and it gets just as hot except the fan kicks on and cooks me while cooling the motor. I would not worry too much as a crapload of your countrymen rideHarleys down under.
I live in Northern Mexico, er Southern California and the summers often get above 100+ F. My wife has a FXDL and has never had a problem, not have I with my Road King (also a TC 96). You got no worries mate.
Daniel, my advice would be that if you are worried add an oil cooler kit - http://www.harley-davidson.com/gma/g...bmLocale=en_US- and run synthetic oil. Least then you've covered your bases.
It will only overheat if your sitting still for a decent amount of time. If stuck in heavy traffic hit a backroad or just pull over and let her cool down for a bit. The aircooled bike needs to be moving to keep cool. Run Syn. Oil and just stay out of heavy traffic and you will be fine.
Daniel, Aside from the oil cooler add-on, you can consider the heat shields that mount under the seat. Still, as already said, if you are not moving, that 96 will broil. Riding here in NYC, heavy traffic is so unavoidable I just kept my 88.
danilet...like others have mentioned, god syn oil will take care of any issues, unless heavy bump/bump traffic like thelawdoc, once you're moving...its coolin
Daniel, look at nightrider.com. Buy the XiED for you new bike. They only work on the 07 and 08 models. 15 minute install. I'm in SoCalifornia, it gets hot here. The bike no longer gets hot sitting at stoplights. For $100 the XiED puts your air/fuel mix where it should be. It will also run much better than a bike without them. They eliminate the need for an expensive tuner. Add pipes and an open air filter and ride. My Heritage was hotter than my 99 Evo but now it's cooler, by far.
XiED sound slike a good idea, but to be honest with you, I and Im sure lotsa people like me dont want anything aftermarket in their harnesses or ECM. Just me i guess. SERT will be the most expensive way to go no doubt but in the hands of a good tuner, you get a bit more power and a cooler running engine. Wont be emmissions legal, but you and your engine wont be burning up. Note: if you ordered an HD international model, then your going to have active air exhaust with Catalytic converters. I WOULD NOT recommened any fuel enrichment devices, otherwise you'll smoke your converters and if you have strict emmission laws and have to get it tested, you may not like the bill to get it to pass.
