Quick Question on "decel popping"
Old 05-15-2008, 03:01 PM
golfblues's Avatar
golfblues
golfblues is offline
Received 1,540 Likes on 932 Posts
Default RE: Quick Question on "decel popping"
Whats to fix, you can leave it as is & just ride or you can add pipes, fuel management, air cleaner & spend lots of $$$. Buyers choice. All depends on what you want out of your ride.
Old 05-15-2008, 03:04 PM
Jrsess's Avatar
Jrsess
Jrsess is offline
With the stock pipes it still pops. You just don't hear it!
Old 05-15-2008, 03:07 PM
DannyZ71's Avatar
DannyZ71
DannyZ71 is offline
ORIGINAL: golfblues
At the very most, I'll probably add some Rinehart slip-ons. I don't want the bike to run lean. Therefore I'd want them to correct that condition before leaving the shop with it, and without having to spend a small fortune for upgrades that I really don't want. I just don't want the bike to run that lean.
Old 05-15-2008, 04:51 PM
DanDeuce's Avatar
DanDeuce
DanDeuce is offline
Make sure you have a good seal between your header pipes and your muffler (s) , on decel it will suck air in and pop if not . On my V&H I had to remove the bolt stop on the clamp , at the tightest I could turn the muffler with little effort . I also used some Hi-temp silicone , now it pops maybe 25% of what it used to and much quieter , more of a rumble .
Old 05-15-2008, 11:25 PM
vibr8ir's Avatar
vibr8ir
vibr8ir is offline
Put high temp copper gasket sealer on all joints let dry overnight and retork all clamps after it's hot .. Steve
BaldHOG1222
08-03-2012 04:32 PM
cbchev68
09-12-2011 06:18 PM
tom lipke
07-21-2009 12:23 AM
hippharley
Exhaust System Topics
05-25-2007 11:14 AM
XL Junkie
05-15-2006 12:22 AM
Quick Reply: Quick Question on "decel popping"
