ethanol damage??????
#31
RE: ethanol damage??????
ORIGINAL: Da Gumpmeister
The problem eliminating lead back in the 70's, was a valve lubricating issue, not an octane problem.
Hester, obviously I am a long a$$ed ways from you, but scout around, and see what the small local airport has. I used to run Avgas High octane for that very same reason. Just a thought. Like I say, do not know what Cal. has for avgas tho. And if available to public. (?) Here in the middle of corn country, we have been using 10% for years. When I can afford it, I stop at the BP in Isanti, and fill up with Racing fuel, they have a pump for it there. BUT get the wallet out. They won't even give me a gallon if Momma flashes them.
The drawback is the water and rust. Well, everything isa tradeoff.
