Rubber mount vs solid mount engines
RE: Rubber mount vs solid mount engines
The A vibrates less than the B at speed. What you are feeling on the tourers at idle is low frequency vibes at low RPM. The higher frequency vibes at higher RPM are absorbed by the rubber mounts whereas thevibestransferright though to the frame on the solid mount.
Hard mount feels more like a motorcycle to, unless you're cranked up to about 105.The it feels like a runaway jackhammer.The little 4"x3" mirrors (on apes) look about 4ft X 3 ft. But, I loved the crap out of the thing. She's no longer mine (I screwed up!). Old fart.
ORIGINAL: kmm
Number 1 Counterbalancing consists of a different crank ( Heavier crank than the A motors)
Number 2 More weight less power (thats why the B motors are in the soft tails not the touring bikes)
Number 3 Centrifigal force makes the B motors buzz thru the the floorboards due to the heavier crank
Number 4 A motors shake at idle , B motors dont
Number 5 As for The post that mentioned rubber mounted engines get more power to the ground how come MOROSO and tons of drag racers all run SOLID
mounted motors?
Number 6 Come to the table with some knowledge
mounted motors?
See the irony in your knowledge comment?
I like the balanced motor in my 07 FXSTC, However, that balancer does soak up a couple ponies and foot pounds of tourqe. the best deal is have one of each.[sm=americanasmiley.gif][sm=drooldude.gif]
[IMG]local://upfiles/49894/69CEE3D7BEDE458EA343524A86F860CC.jpg[/IMG]
ORIGINAL: dynamike74
#5 - Drag racers run solind mounted motors WITHOUT a counterbalance.
ORIGINAL: kmm
mounted motors?
mounted motors?
The quote regarded rubber vs. solid mounted to get the power to the ground and stay in place
I have owned 5 V8 Vegas I know torque
As for counterbalancing small blocks the 400 small block was so countered balanced it was EXTERNALLY balanced same with the 383 stroker motors
At 52 I'm not sure which is best - thinking about it briefly I'd err of the vib and shake as its gives me a good excuse not to service the ol' lady when I can't feel anything from the waist down!
