Brake light stays lit. HELP!!
Old 04-28-2008 | 01:12 AM
swilsondds's Avatar
swilsondds
Default Brake light stays lit. HELP!!
I've got a '95 RK and the damn brake light wont shut off. Activating the front or rear brake has no effect. The brake light stays the same. Any ideas...? Thanks in advance.
Doc
[IMG]local://upfiles/59327/6CDB346D9F9D4688BE787F30917D8DC7.jpg[/IMG]
Old 04-28-2008 | 01:23 AM
clap's Avatar
clap
Default RE: Brake light stays lit. HELP!!
Sounds to me you have a switch stuck in the on position.
Old 04-28-2008 | 05:07 AM
e6fmf's Avatar
e6fmf
Have you done, or has any work been done, to the grips, switches, brake lever? Make sure you have solid contactwith brake master cylinder and throttle grip.
Old 04-28-2008 | 04:54 PM
jag1886's Avatar
jag1886
I had the same problem after working on thehandlebars, it was the little spring that holds the switch in place on mine.
Old 04-28-2008 | 05:40 PM
Da Gumpmeister's Avatar
Da Gumpmeister
The overwhelming majority of the time, front brake light switch on the handlebars. Could be a pinched wire there, BUT ensure it IS NOT the switch, B4 tearing anything apart. It is the VERY first thing I look at when someone has a brake light problem.
Old 04-28-2008 | 06:38 PM
dirtnap664's Avatar
dirtnap664
+ 1 with handlebar issue. My buddy changed out my grips for me and right after he did it my brake light was stuck on.
Old 04-28-2008 | 07:54 PM
billnourse's Avatar
billnourse
It is very likely the switch for the front brake. That's what it was on my '95 Roadking. Try pushing the brake lever forward and see if it goes out. The lever just might not be going back to it's right position after you apply the brakes.
If you have had the front controls apart on the right side it might be that you didn't get things back together just right.
Bill
drsnipes
12-03-2023 01:18 PM
Mr Brown
05-12-2015 07:01 PM
redemption denied
04-09-2010 07:01 PM
beanbag
05-19-2008 01:58 AM
Jonny Cannon
07-11-2007 09:19 AM
Quick Reply: Brake light stays lit. HELP!!
