Maintenance for a bike that hasn’t been touched in 3 years
RE: Maintenance for a bike that hasn’t been touched in 3 years
brake pads, tires, brake fluids, gas, all 3 hole fluid change + filter, charge battery...(new?).. test ride it..check it over again..
#1 check the tires as they will be bumpy as $hit on your first 50-100 miles. Any cracks-(even one) replace them right away.
2. drain fuel and refill with new 91 fuel with 4oz redline S-1 fuel system cleaner (www.myoilshop.com ) This will clean the whole fuel system like new
3. Change all the oils & filters
4. Change out the spark plugs
5. Replace the battery
6. Pre-oil the engine like descibed above. (some guys use marvel mystery oil in plug holes)
7. check all rubber fuel & oil lines
Lots of people will tell you this is too much but I have re-road conditioned several bikes after some jamoke just let them sit like that. If you do all of this you won't have to bother with anything else.
ORIGINAL: KBFXDLI
Here's your winna!!
Coleazy
Oil Archive (no new posts)
03-26-2017 11:58 AM
