Air dryer
Old 04-09-2008, 01:21 PM
chazzy's Avatar
chazzy
chazzy is offline
Default RE: Air dryer
I use my blow gun on my air compressor. Gets the water off fast and you can basically pin point where you want to blow the air.
Old 04-09-2008, 01:23 PM
Scrapin's Avatar
Scrapin
Scrapin is offline
Custom Dynamics sells the Metro Airforce Blaster for $175.00. Best deal I've seen. http://www.customdynamics.com/air-fo...ycle-dryer.htm
Old 04-09-2008, 01:35 PM
JBaker421's Avatar
JBaker421
JBaker421 is offline
Big Kahuna HDF Member
Compressed air from a compressor is loaded with dirty water and oil. Unless you have a high quality moisture trap (such as painters in body shops use)in line, you're really putting a lot of crap on the bike.
When air is compressed, it heats up. When it cools in the tank in condenses and saturates the tank. That's why you have a drain at the bottom of the tank. When it decompresses as in being blown out the line, it gets very cold. Moisture condenses and blows onto the bike. It is oily because of the compressor. (most good compressors.)
This is how refrigeration works. You have a condensor and an evaporator. When you use your air compressor the head andtank get hot. When you blow out air, you can get frost on the blow tip.
A good oil and moisture trap for your compressor can cost more than a good gas powered leaf blower.
Leaf blower here.
Old 04-09-2008, 01:40 PM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
ORIGINAL: Scrapin
Not all that much of a difference, but you can get them here for $169.95..
http://www.auto-ease.com/cgi/ppcart....201&dryers
Old 04-09-2008, 01:52 PM
cray49a's Avatar
cray49a
cray49a is offline
I use the shop vac with the 200 mph blower option. Works great!
Old 04-09-2008, 02:19 PM
NC Pirate's Avatar
NC Pirate
NC Pirate is offline
I use a cheap electric leaf blower. I was afraid my gas powered one would blow oily residue onto the bike....
Old 04-09-2008, 03:53 PM
Tinkermc's Avatar
Tinkermc
Tinkermc is offline
I have a back pak blower that works very well, then a micro fiber cloth
Old 04-09-2008, 04:12 PM
Firetender's Avatar
Firetender
Firetender is offline
I'm a clean freak, and I've used my gas-powered leaf blower for 7 years to dry off the bike. It's NEVER blown oil or debris on the bike and the nozzle is made out of semi-soft plastic that wouldn't hurt the bike if you smacked it with it. But I would never criticize how someone else throws their money away - that's their business!
Old 04-09-2008, 04:17 PM
Jrsess's Avatar
Jrsess
Jrsess is offline
Airforce blaster,awesome. Also extremely fast.
Old 04-09-2008, 04:31 PM
lrntowrench's Avatar
lrntowrench
lrntowrench is offline
ORIGINAL: Firetender
That's what a friend of mine with a '68 Camaro said. Right up until the time when the leaf blower spit outa chunk of crap that put a scratch in his drivers side quarter panel. He thinks of me every time he sees that scratch in the original paint. To each his own - just like insurance.
Quick Reply: Air dryer
