Cleaning Tanks???
Old 03-31-2008 | 06:44 PM
J DOG's Avatar
J DOG
Default Cleaning Tanks???
I bought a set of tins last year with plans on getting them custom painted. Im wonderin what way to go about cleaning out the insides of the tanks, do they sell something you can put in to clean and remove surface rust and or debris? Also should i use a sealer once cleaned? If so what brand? Any info will be appreciated, thanks.
Old 03-31-2008 | 07:05 PM
ranger56528's Avatar
ranger56528
Default RE: Cleaning Tanks???
I resealed the tank on my 80 FLT got the sealer from Harley,used small nuts and bolts to break lose the junk inside,worked great....
Old 03-31-2008 | 07:06 PM
Dorkman's Avatar
Dorkman
Here are a couple of rust removal products. The safe rust remover takes an longer soaking. The Kreem product has an acid to attack the rust, then a coating for the tank. I've used the safe one...didn't like the idea of acid but I'm sure its OK if you take care. It's fairly popular.
http://www.ultraoneusa.com/shopdispl...t+Rust+Remover
http://www.kreemproducts.net/p-18-kr...mbo-combo.aspx
Old 03-31-2008 | 07:09 PM
biz44's Avatar
biz44
I have used the Kreem products many times in the past while restoring a older bike with the original tank. many times the inside of the tank has quite a bit of rust, and it does need to be addressed in order to do a quality resto job....at least in my shop it does.
In any case.....you will be safe with any of the Kreem product line. Even for first time users its quite easy to work with.
Old 03-31-2008 | 07:31 PM
Diavolo's Avatar
Diavolo
KREEM
Old 03-31-2008 | 07:39 PM
J DOG's Avatar
J DOG
Thanks guys, i'll have to try that stuff. The tanks are'nt in bad shape just been sittin a while.
Old 03-31-2008 | 07:41 PM
nutmagnet's Avatar
nutmagnet
I took my tanks to a radiator shop. They cleaned them, pressure tested them and coated them for 40 bucks.
Old 03-31-2008 | 08:04 PM
Mikey 1450's Avatar
Mikey 1450
Take a look at www.POR 15.com. I like thier tank sealant better than the others. Good Stuff. Prepping the tank properly prior to sealing is the key.
09 YELLOWBIRD
07-24-2013 03:43 PM
hogcowboy
Exhaust System Topics
07-08-2012 05:39 PM
Roosterboots
The General Motorcycle Forum
22
02-09-2010 06:52 AM
tom lipke
01-09-2009 04:09 PM
Helimad
03-09-2007 10:46 AM
Quick Reply: Cleaning Tanks???
