Excessive Heat
Old 03-30-2008 | 09:52 AM
SA315B's Avatar
SA315B
Default Excessive Heat
I was under the impression that the “fix” for excessive engine heat was automatically installed (or programmed) into 08 bikes, now I hear that this has to be activated by the dealer.
Is there some problem caused by or related to the fix?
Does anyone know of any reason why I should not have it activated?
Old 03-30-2008 | 09:54 AM
stro1965's Avatar
stro1965
Default RE: Excessive Heat
Not sure what "fix" you're talking about. The '08 engine is the same as the '07 engine, no changes. If you're referring to the download that shuts down the spark to the rear cylinder, I'm not sure if the '08's come stock with it or not. Not much of a fix though, as I see it.
Old 03-30-2008 | 10:11 AM
SA315B's Avatar
SA315B
ORIGINAL: stro1965
That is what I am referring to, I was assured that the 08 came with it and did not need the download. I’m just wondering if there is some sort of problem associated with it that would require it to be activated.
The only one I can think of is if it is not temperature regulated it would prevent the rear cylinder from warming up when the bike is first started. As I am about to go in for the 1,000 mile service I would like to have this system explained by someone who knows how this works before I have it activated.
Old 03-30-2008 | 10:21 AM
warthawg's Avatar
warthawg
Old 03-30-2008 | 10:24 AM
electaRICK's Avatar
electaRICK
08's are NOT as hot as the 07's!!!!
Old 03-30-2008 | 10:31 AM
GGC's Avatar
GGC
And not nearly as nice!!
Old 03-30-2008 | 10:36 AM
stro1965's Avatar
stro1965
ORIGINAL: electaRICK
WHY???
Old 03-30-2008 | 10:39 AM
electaRICK's Avatar
electaRICK
have to ask the Mo Co that Q.
maybe all my complaints in here a year +1/2 ago, helped?
Old 03-30-2008 | 11:52 AM
skiahh's Avatar
skiahh
Does it apply to the other models, too, or just the touring models?
Old 03-30-2008 | 01:08 PM
stro1965's Avatar
stro1965
I'm not aware of any changes that would make on '08 run cooler than an '07.
Quick Reply: Excessive Heat
