Excessive Heat
RE: Excessive Heat
08’s may be cooler than 07’s but I can assure you my 08 SG is a hell of a lot hotter than my 03 RK was. I took a ride down Key West’s Duval Street last night and swore it would be the last time before I found a solution. If this doesn’t work I’ll have to try heat shields.
RE: Excessive Heat
Keep in mind that EITMS only works at idle. Once you blip the throttle a bit that rear cylinder kicks back in. It's really not doing much at all except at idle. You might want to look at richening up your AFR's with a PCIII or something.
RE: Excessive Heat
My O8 Ultra is running no cooler than my 07 Heritage was. Even after I put new pipes, SE AC and SERT on the Heritage. Not going to go around that block again. Was on a charity ride here in South Florida yesterday and it got pretty warm in traffic. Ordered RJ Heat Deflectors last week.
Not doubting anyone elses experience, but that's mine. Don't get me wrong I loved my Heritage and I love the Ulta even more, the heat ain't that bad.
RE: Excessive Heat
ORIGINAL: warthogsf
I did the same as you with the SERT, but made sure they richened up the AFR. That helped a lot. But the biggest help was the RJs Originals. You will really be pleased with them, especially this summer.
