Oil leak got worse!!!
WTF!? This leak sprung out of nowhere. First it was some oil residue now it is a full blown mess!
This pisses me off! I thought that perhaps one of the breathers were plugged creating crankcase pressure, thus pushing oil out here. I checked the breathers and they appear to be fine.
I tried using some case sealant on the pin hole last night but it doesn't appear that it helped, in fact it got worse.
What do y'all think?
Here's pics. You can see an air bubble where there is obviously air pressure forcing the oil out (arrow points to the air bubble)
RE: Oil leak got worse!!!
Are you sure that it's coming from between the cases? If you could clean up the oil and get a good picture posted of the pin hole you refer to, it would be helpful. It almost looks like the oil is dripping on the center casting and running down to the case where it puddles.
ORIGINAL: DGlide04
Looks like a problem. I hope its not a porous case. I thought those were problems of the past. I would take it to a friend of mine thats more knowledgeable than me.
On my 02 Electra Glide The dealer replaced the rear jug on mine due to a pin hole in the casting. I had bought it used 2 years ago but they gave me a 6 month warranty on the bike and it developed a leak a couple months after I purchased it.So I got pretty lucky. I would say yours is a bad casting as well.
Clap
Clap
Hey, Baron. Looking like a "bummer" first of all, and then either a porous casting or a crack in the case.Can you see the "actual" hole/crack? Or is it, for lack of a better word, "microscopic" (not visible to the naked eye)
I am attempting to fwd this whole post to Scott, an indy who does case machining and engine building, to see what light he may possibly shed.
I would tell you what I'd do "if it were mine" but I do not want to add to the fray here. So will keep it to myself, for now. If Scott comes back with the same idea, then I'll post it.
Doesn't look like there is a whole lot of pressure in that area, but I would like to know what is directly under the pin hole. Probably just oil splashing around. Looks like a very tight area for any kind of a welding tool, for a fix, but a person with some experience may have a better answer. You might try digging out the pinhole a bit, then using JB-Weld, a two part mix. The stuff is tough and holds very well.
Guys, it's leaking from a spot where there appears to be a machined notch in the two case halves that is filled with case sealant. I would assume the "notch" is there to help when splitting cases.
