Buff my Forks ???
Old 02-04-2006, 11:47 AM
T Tommyt's Avatar
T Tommyt
T Tommyt is offline
Default Buff my Forks ???
Have any of you done this I want to pull the front wheel and fender and completely buff-out //Polish my front (lower forks)
What products are used and what type of wheel and how much speed ,like can I use a high speed drill
or will I need an air driven gun
I tried jewelers rouge and a drill it smoothed the finish but did not shine the fork
I am trying to get a chrome like appearance
Old 02-04-2006, 01:50 PM
blowe's Avatar
blowe
blowe is offline
Default RE: Buff my Forks
I did this with some touring lowers.I removed them
where looking at your post I think you're going to
try doing them while they remain on the bike.
There was a clearcoat on the legs that had to come off first.
I used aircraft stripper and the clearcoat bubbled up
and wiped off easily.
I noticed an immediate difference in the color.They
appear much more silver,for lack of a better term,than
they did with the clearcoat.
Next I started with 800 grit wet or dry paper and worked
my way through 800,1200,1500,and 2000 if I remember
correctly.After finishing the 2000 I cleaned them up
and used a dremel with a fine buffing wheel and as you
suggested above ,jewelers rouge.
Turned out great other than it was some work.
Old 02-04-2006, 10:38 PM
T Tommyt's Avatar
T Tommyt
T Tommyt is offline
Thanks for the info
Today I had a custom shop give me a price of $120.00 to do them. Would you do it over or would you pay the $$......?
Old 02-04-2006, 11:13 PM
blowe's Avatar
blowe
blowe is offline
I'd do them myself.It won't take that long and isn't difficult.
A little elbow grease is all it takes.
Save the $120 for something else you're wanting.
Are you against chrome lowers? You can buy those
online from the HD dealers with the 20-25% discounts
for about $200. That reason alone makes it hard for me to
justify paying $120 to have a used set polished.
Old 02-04-2006, 11:14 PM
cowboy Harry's Avatar
cowboy Harry
cowboy Harry is offline
Why not just chrome em??????????
Old 02-05-2006, 12:06 PM
mikeisglidn's Avatar
mikeisglidn
mikeisglidn is offline
buffing will make them look much better...........but they will require continious buffing to keep them looking good. good luck!!
Old 02-05-2006, 04:41 PM
Scout's Avatar
Scout
Scout is offline
Mikes right. You have to buff them forever more. If you want the look, get them chromed. I buffed mine on my last Goldwing, and it was a pain in the ***. I ended up clearcoating them, after buffing. All the work wasn't worth it.
Old 02-06-2006, 02:38 AM
T Tommyt's Avatar
T Tommyt
T Tommyt is offline
ORIGINAL: Scout
Ok thanks but I have fugly forks and need to do something!! I cannot find these Lowers you speak of for $200 and I don't think I would dislike chromeqt all , I was more concerened with Price this is why I had considered Polishing them
can anyine post a link for me
the Bike is FXDX "T"
Thanks
Old 02-06-2006, 11:45 AM
T Tommyt's Avatar
T Tommyt
T Tommyt is offline
.[sm=americanasmiley.gif]
Old 02-06-2006, 12:12 PM
Scout's Avatar
Scout
Scout is offline
There's preffered chrome and powdercoat in FL.
I'm sure if you call your dealer he will be able to suggest a chroming house. There's a ton in Toronto, so there must be a bunch where you are.
Quick Reply: Buff my Forks ???
