Anyone put on an oil cooler?
Old 03-17-2008, 06:51 PM
drummerart's Avatar
drummerart
drummerart is offline
Default Anyone put on an oil cooler?
I put on a "premium" harley-davidson oil cooler on my 07 Heritageand I got it all installed and it says to use a sealant to hold the chrome cover on. Does anyone know what kind of sealant they are talking about?
Old 03-17-2008, 06:57 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Default RE: Anyone put on an oil cooler?
I will be installing one as soon as it arrives.
Doesntthe cover bolt onbolt on?
Old 03-17-2008, 07:17 PM
barjbar's Avatar
barjbar
barjbar is offline
Silicone probably. I agree. Are you sure you're supposed to glue it on?
Old 03-17-2008, 07:21 PM
gman's Avatar
gman
gman is offline
Mine just bolted on over the cooler.
Old 03-17-2008, 07:25 PM
drummerart's Avatar
drummerart
There are no bolt holes on the cover and the second page of the directions shows where to put the sealant, but doesn't tell you what kind. This is the cooler for softails not the one for FLH. Just wondering if anyone here would know.
Old 03-17-2008, 08:57 PM
screwball's Avatar
screwball
screwball is offline
Put Jagg coolers on my Springer and wife's Sportie, Neither had chrome covers. jagg makes the Harley coolers.
Old 03-17-2008, 09:09 PM
DesertSpeed's Avatar
DesertSpeed
DesertSpeed is offline
Account Suspended
My stock oil cooler works just fine.
Old 03-17-2008, 11:12 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
Yes. I did it last season. I used Permatex high temp sealer. Holds on tight.
Old 03-21-2008, 12:43 PM
drummerart's Avatar
drummerart
Called the stealer and they told me to use RTV clear silicone. Worked great. Had to find a 7/16" hex head socket to tighten the new oil filter adapter. None of the hardware or autoparts stores around here stock that size, so I borrowed one from the guy that works on my car and then I special ordered one in case I ever have to work on it again.
Old 03-21-2008, 12:52 PM
sleepneagle's Avatar
sleepneagle
sleepneagle is offline
My thoughts for leaving the chrome off.
1. Chrome does not dissipate heat as quickly as a painted surface.
2. by adding a cover you slow down heat transfer
3. one more thing to polish, when you could be riding
4. cover traps dirt, making the cooler harder to clean.
Quick Reply: Anyone put on an oil cooler?
