Anyone put on an oil cooler?
Old 03-21-2008, 01:05 PM
drummerart's Avatar
drummerart
drummerart is offline
Default RE: Anyone put on an oil cooler?
Only reason I put the chrome cover on was to try to protect the fins on the cooler. True, it looks good, but with the cooler being in front of the motor I worried about it taking a hit from rocks or other road trash and splitting while I'm riding, so I put the cover on.
Old 03-21-2008, 01:17 PM
Da Gumpmeister's Avatar
Da Gumpmeister
Da Gumpmeister is offline
ORIGINAL: drummerart
Called the stealer and they told me to use RTV clear silicone. Worked great. Had to find a 7/16" hex head socket to tighten the new oil filter adapter. None of the hardware or autoparts stores around here stock that size, so I borrowed one from the guy that works on my car and then I special ordered one in case I ever have to work on it again.
FYI - Not that you'll ever need it for this, but that is the same size allen as on the OLD Harley Star hubs lug nuts(1936-1966). Not a real common one, as you found out. Some "idiots" own it in 3 different types. Straight, 90*, and 3/8" socket drive.
Glad you got the cover attached. Feels good, huh?
Old 03-21-2008, 02:13 PM
jag1886's Avatar
jag1886
jag1886 is offline
You just use a good silicone made for engine work,I'd use the black color so it doesn't show.
As far as the 7/16 allen wrench I used a short 1/4"bolt with 3 or 4 nuts on it and inserted that int a short socket and used that as an allen wrench. Worked perfect.
GaryInDelta
10-14-2016 03:51 PM
Rickr01
03-10-2013 01:40 PM
dgriffith
03-31-2008 09:58 AM
Renegade1
Oil Archive (no new posts)
12-02-2007 08:36 PM
NCCopBikeRider
09-19-2007 11:59 AM
Quick Reply: Anyone put on an oil cooler?
