Do you run red lights or is there a trick to tripping the light??
#51
RE: Do you run red lights or is there a trick to tripping the light??
For reference...
346.37(1)(c)4.
4. Notwithstanding subd. 1., a motorcycle , moped, motor bicycle, or bicycle facing a red signal at an intersection may, after stopping as required under subd. 1. for not less than 45 seconds , proceed cautiously through the intersection before the signal turns green if no other vehicles are present at the intersection to actuate the signal and the operator of the motorcycle , moped, motor bicycle, or bicycle reasonably believes the signal is vehicle actuated. The operator of a motorcycle , moped, motor bicycle, or bicycle proceeding through a red signal under this subdivision shall yield the right-of-way to any vehicular traffic, pedestrian, bicyclist, or rider of an electric personal assistive mobility device proceeding through a green signal at the intersection or lawfully within a crosswalk or using the intersection. This subdivision does not affect any authorization for a bicyclist under subd. 2.
346.37(1)(c)4.
