Neutral light out
Neutral light out
I have a 03EG classic my neutral light went out. I have checked the wires and cleaned the postsand it still will not light. I also checked to see is the circuit was open when in gear and closed when in neutral.This was all correct. Can it be the bulb it self? Can I just change that 1 bulb or are they LEDS. Thanks for any info.
RE: Neutral light out
Same thing happened to me yesterday. Light worked fine when I fired it up a few weeks ago. Went to take it for a short ride yesterday and no light.
If the circuit is good and it is the bulb you have to replace the whole cluster (L/Turn, Hi Beam, N Oil, R/Turn) on the fairing, they are LEDs and it is one piece!
Doesn't all lights glow when you first turn the ignition switch to start before starting the motor? I'd say if it doesn't glow then, it's the bulb.
Thanks to all I just switched the bulbs from my high beam bulb to the netral bulb until I get the part.
Thanks to all for the help!
It was the bulbs I just replace the one that was out I should have replaced them all!!
