sparking from under seat
Guest
Posts: n/a
RE: sparking from under seat
ORIGINAL: electaRICK
could we get about 5 more people to repeat what I said!..??????
sparks mean LOOSE connection or bare wire making contact with metal,,,,, keep looking
There you go....
In all seriousness lee33 electrarick is correct...good luck finding it. Yu wouldn't want to have a "shocking" experience the next time you go for a ride...especially not there[&:]
ORIGINAL: Bluerose
Who needs 5 people...I'll just repeat it 5 times:
There you go....
There you go....
Lee33, look at the red cable connection, the positive cable, from the battery down to the connection on the starter.On my sportster years ago the cable actually corroded thru where it was crimped into the terminal on the cable. It happened to me and broke in half when I pulled up in my driveway after a nice drive in the country. I just read a story about this happeningto the author of the article. This cable just reaches the two connections, if you can find an electrical shop to make one, make it about a half inch longer. Look at this connection and for other loose connections. Good luck
[:'(]sparks mean LOOSE connection or bare wire making contact with metal,,,,, keep looking
[:@]sparks mean LOOSE connection or bare wire making contact with metal,,,,, keep looking
[&:]sparks mean LOOSE connection or bare wire making contact with metal,,,,, keep looking
[8D]sparks mean LOOSE connection or bare wire making contact with metal,,,,, keep looking
Are these 5 OK Rick?.
