LED turn signal brands?
RE: LED turn signal brands?
I replaced my rear lights with the Kuryakin Panacia system last year. Much brighter than stock, plus the taillight will signal with the turn signal and the lights blink quickly for a couple seconds when the brake is applied.
Check this set up.It is the panacea system.http://www.customdynamics.com/harley...al_panacea.htm
www.heavycycles.com
Joe is a personal friend of mine , and I used to work for him
www.heavycycles.com
I got the Kuryakin Panacias all around & they were a great choice. Turn signals are running lights, all rear lights can brake normally or quick flash 5 times together when a brake is applied. Also there are 2 rear blinker lights for a turn, the turn signal itself & the corresponding half of the tail light. The colors are great too with smoked lenses.
Try this old thread for mine.
https://www.hdforums.com/m_2567671/tm.htm
The new Geniuses clusters are suppose to be about 30-50% brighter than the Radiance clusters, which are already insanely bright. I'm going with the Geniuses myself. Custom Dynamics sells both.
I also went with the Kuryakin Panacia system both taillight and turn signals on my 08 RK. I've been very pleased with them and like the flashing taillight with braking. Flashes 5 times then stays on steady. If sitting in traffic and see an approaching car, I just take my foot off the brake and reapply it which starts the flashing again. Only problem I had is a little water leakage in the taillight when washing the bike. A little silicone solves that problem.
97dyna
06-05-2011 11:15 PM
