bike storage/pool chemicals
Old 02-26-2008, 03:48 PM
Crazy Biker's Avatar
Crazy Biker
Crazy Biker is offline
Default RE: bike storage/pool chemicals
Pool chemicals will change chrome yellow.
Old 02-26-2008, 03:56 PM
Big Sled's Avatar
Big Sled
Big Sled is offline
Big Kahuna HDF Member
Received 8,487 Likes on 4,380 Posts
Man! You got some bad azz spiders in that pump house if you need to carry a 357mag in there[]!
ORIGINAL: lh4x4
Chlorine fumes are very caustic to metal. My S&W N framed 357 cylinder froze up from just walking into the village water pump house to check water samples. It turned green.
Old 02-26-2008, 04:02 PM
TJB50's Avatar
TJB50
TJB50 is offline
Don't do it! I took a HazCom seminar and the instructor mixed chlorine and brake fluid togther in a small can outside and it was one-h*ll of an explosion.
Old 02-26-2008, 04:17 PM
whaap's Avatar
whaap
whaap is offline
I don't know the answer but I know that I would not store them together.
Old 02-26-2008, 04:21 PM
Da Gumpmeister's Avatar
Da Gumpmeister
Da Gumpmeister is offline
ORIGINAL: Big Sled
ORIGINAL: lh4x4
FUG, U azwipe, I jus spit coffee all over the keyboard, dammed, I'mSTILL laffin' GAWD, good oneLMFAO
Old 02-26-2008, 04:25 PM
miketami's Avatar
miketami
miketami is offline
Bad idea. Not sure about all the explosion/fire comments, but I do know that you will see pitting on all aluminum and chrome parts come spring.
Old 02-26-2008, 06:09 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
I used to use clorine and pool chemicals to treat chrome on some old bobbers i would build in college... it would yellow and almost give the chrome a brass look... i discoved this when i picked up a bike that was stored in a barn where the pool chemicals where kept... so we tried it... sure enough... eats that chrome up! i would get that bike out of there ASAP! if it does that to a chrome plating... alum is a much softer metal
Old 02-26-2008, 06:18 PM
TNwilliams's Avatar
TNwilliams
TNwilliams is offline
The pool chlorine is an oxidizer, and will enhance the build up of a protective coating of ferrous oxide on your bike[sm=smiley26.gif].
Chlorine + gas won't explode until you light it.[sm=crossbonesgif.gif]
Old 02-26-2008, 07:20 PM
robbie52's Avatar
robbie52
robbie52 is offline
DO NOT STORE POOL CHEMICALS IN A SHED WITH ANYTHING YOU CARE ABOUT, INCLDING GOOD TOOLS ETC. WHETHER YOU CAN SMELL THE CHLORINE OR NOT YOU WILL HAVE CORROSION PROBLEMS.
Old 02-26-2008, 07:25 PM
biz44's Avatar
biz44
biz44 is offline
Just drain the pool, put a roof over it and keep the bike in there.....done deal.....no need for any more pool cleaning crap!
Quick Reply: bike storage/pool chemicals
