What's cheapest TC88B upgrade to 100TQ/100HP?
RE: What's cheapest TC88B upgrade to 100TQ/100HP?
ORIGINAL: Gutman
That may qualify in your area, but how can you base that as a response. The Imdies in my are don't know squat about Twin Cams. I have built hundred's of bikes with SE parts that make well overa hundredhorse. I am a dealer. Don'tproject personal experience to everyone. Next time quote about higher priced and maybe using other parts, or don't go to this dealer to help out. Some dealers are good.
ORIGINAL: JeffreyLebowski
Get on craigslist and do a search for V-MAX or ZRX....sorry man just jerkin your chain.
I can tell you what not to do. Don't go to your dealer. Screaming Eagle parts are expensive, and I don't think it's because they are the best. My bike runs great now, but I'm pretty sure I could have had better results for cheaper. Ask around a lot, find a good independent shop in your area.
I don't care if you don't stand up for what you believe. Dealer "S" aren't the problem. Labowski is in MD and Deuce is in MO.
hate to say this but I really don't think just 95 inch will get you 100/100 by it's self you will at the least need cams so might as well go with the porting when torn down. also I have been told it is best to get your cylinders rebored or use ones that have been run in as apposed to new...price I have no idea except cams 1300 for me and that is probably the biggest increase you can get cheap..
ORIGINAL: grumpy irish again
ORIGINAL: Gutman
That may qualify in your area, but how can you base that as a response. The Imdies in my are don't know squat about Twin Cams. I have built hundred's of bikes with SE parts that make well over a hundredhorse. I am a dealer. Don't project personal experience to everyone. Next time quote about higher priced and maybe using other parts, or don't go to this dealer to help out. Some dealers are good.
Deal or no deal I dont know. Surdyke in Festus Mo. Is offering 95 cu.in. upgrade for 1399.00 w/your choice of cams installed. Doesnt sound to bad , does it?
ORIGINAL: pokie
Thats with labor. I know, what about all the hidden fees because thats what I asked the guy at the service counter. He told me that the kit prices were dicounted and that the labor was 50% off through Feb. I tried to get Docs to give me the same deal they came down to 1800.00 and said thats the best they could do. The deal at Surdyke has been going since Thanksgiving.
ORIGINAL: LowRyder
Just curious, how do you figure 2-3K or is that w/o installation?
Lowryder
ORIGINAL: sonar_chris
GMR performance or Headquaters 95" kits. With a proper dyno tune you should get 100/100 reliable with good drive ablility. all in all youll probably spend anywhere from 2-3 grand depending on how fast you want to go.
Chris
Chris
Lowryder
Chris
Well, I bought a used set of jugs and pistons, a used set of cams, and just need a bit more to get it started... I don't think I will be anywhere near 100/100, but who knows, I might get lucky... for me, total hp/tq is not that important. I just want something that will haul my fat @ss around, quicker than what I have now... don't forget, with the stock carb, you might need to get some work done on it, as well. I have the stock 40mm, and am thinking of having it worked (along with the heads)... just a matter of getting the money together...
