Slowing Down - Brakes or Shifting
Old 01-25-2008, 12:36 PM
2Wheels Engine or no's Avatar
2Wheels Engine or no is offline
Default Slowing Down - Brakes or Shifting
Do you slow down by applying the brakes or downshifting? Is there an advantage to one over the other? Wear on the clutch as opposed to brake pads?
Thanks for any input!
Old 01-25-2008, 12:39 PM
BrockRKC06's Avatar
BrockRKC06
BrockRKC06 is offline
Default RE: Slowing Down - Brakes or Shifting
brakes are cheaper
Old 01-25-2008, 12:40 PM
Madfun's Avatar
Madfun
Madfun is offline
I use a combination of both. I feel I have a bit more control if I am in the right gear at all times.
Old 01-25-2008, 12:41 PM
cbigbie191's Avatar
cbigbie191
cbigbie191 is offline
Both
BMdeckie's Avatar
BMdeckie
BMdeckie is offline
I just drag my feet.
Old 01-25-2008, 12:49 PM
PoorBoy's Avatar
PoorBoy
PoorBoy is offline
Old school has ALWAYS been about downshifting whenever possible. Always my preferred first chioce, BUT....... Today I find myself having to ride MUCH MORE defensively so I do use my brake light as often as possible as a warning to whatever dope is behind me.
I try just tapping the front brake to get the brake light going, do my downshift(s) and then apply both front and rear brakes (70% front, 30% on the rear) as near as I can figure.
I still go through brakes faster than clutches.
I can't stand seeing fellas still on their brakes going around corners, or even pulled-in on their clutches going around corners completly out of gear. That's a very bad habbit they're in.
Old 01-25-2008, 12:50 PM
darkman's Avatar
darkman
darkman is offline
Hi, my advice to you would be to do whatever you are comfortable with, but to just always try and be in the right gear for the right situation. Obviously the brakes are for stopping but you also need to change down so as not to labour the engine, you should certainly never de-clutch whilst braking, except when you come to a standstill. Of course by changing down whilst you slow down you are in the right gear to pull away again. I myself don't even use the clutch for gear changes when I am in a hurry. Look at it as a balancing act if you are coming up to a set of corners that you know, you can drop one gear which will slow you down slightly ride through the corners in that gear, accelerate and change up again. People all ride differently so it is very hard to say what is correct or incorrect, but my advice is stay in each gear for as long as possible, be as smooth as possible, and always look well ahead where you are going, ie if you are coming up to a corner look through that corner not where you are at the time.
Oh and don,t let the cost of a clutch or bake pads detract from your riding pleasure it is a small price to pay. That's why you bought the bike.
Old 01-25-2008, 12:58 PM
Thanks for the responses,
I tend to slow by down-shifting as much as possible, using the brakes for any extra decel required. I suppose PoorBoy's comment about applying the brake light for those behind is a good habit to get into as well. I tend to drive my car in the same manner.
Old 01-25-2008, 01:23 PM
sharkeydude's Avatar
sharkeydude
sharkeydude is offline
Both.
Old 01-25-2008, 01:24 PM
NYNickET's Avatar
NYNickET
NYNickET is offline
i do a lil of both. . . . there are times when you just need to stop & fast.
Quick Reply: Slowing Down - Brakes or Shifting
