Slowing Down - Brakes or Shifting
RE: Slowing Down - Brakes or Shifting
Are you guys saying that in the majority of cases when you are coming to a stop,even from highway speeds you just hold in the clutch without letting it out as you downshift thru the gears as the rpm's permit and just apply the brakes.I would think that would be really hard on both the clutch and the brake pads.Besides you're not using the engines compression to slow you down and missing out on that HD rumble we all like to hear on deceleration.I always give the throttle a little shot after pulling in the clutch and downshift through the gears one at a time as rpm's permit and slowly let the clutch out with each downshift.That's what I've always done,maybe I'm wrong and I've ridden bikes since the 70's. I always apply both brakes at the same time too.
Maybe the better answer is which one stops you better and faster? If you need to panic, you better already have the clutch in and the brakes covered. It helps to be downshifting too, incase you need to accelerate out of something - as infrequently as that actually happens.
There's also the fact that you're not always braking at the same rate at every stop. Some need faster braking than others. If you suddenly need to jump on the brakes and you're just downshifting, you're going to lose valuable time and distance grabbing the brakes and pulling in the clutch.... But there's no ONE answer then is there?
And lastly, that little light on the back of your bike isn't lit up when you're just downshifting. That's fine if you're casually riding down a deserted road. I wouldn't rely on the guy driving that truck full of landscaping equipment to notice you slowing down when there's no light to signal for him to put down his bud light and prepare to stop before he turns you into a biker taco though...
I use both down shift to the proper gear and let the engine slow down the bike with out lugging or over reving the engine. I apply both brakes also at the same time. Ifgoing into a corner no brakes( unless you totally screwed up and you hit it too fast) I accelerate out of it though. When looking througha turn you should also turn your head not just use your eyes btw. It was one thing I always remember from my safety course which I took twenty years ago. The instructor a big man on this little bike would always exaggerate the head turn. It looked funny but I always remembered it. It has saved my bacon many a time.
