Screaming Eagle ignition???
My wrench, who recently installed S&S 510 gear drive cams has talked me into putting in Sreaming Eagle ignition. I am not sure I understand the benefits from this although I'm sure there are some. What exactly does it do and what will be the benefits to me?
Marsh
Marsh
RE: Screaming Eagle ignition???
hotter sparke with more voltage. Realistically, you will see and feel no improvement over stock, unless you put it on a dyno. You may see 1 or 2 mpg better at best.
Chris
Chris
If you were building a high compression motor and needed the hotter spark to ignite high octane fuel ( high octane is harder to burn) then I would say its a good idea, but if your staying stock compression, and never going to race I wouldnt worry about it.
Chris
Chris
heritageJ
03-31-2015 05:11 PM
heritageJ
03-28-2015 01:45 PM
