Cut down my windshield today
Old 12-30-2007, 07:33 PM
jad's Avatar
jad
jad is offline
Default Cut down my windshield today
I didn't like the windshield that was on my Springer so I thought I'd try cutting it down. I heard all kinds of stories about how they crack and it takes special tools to do it. Well I mask the entire sheild then drew my lines on it and went to the band saw. No problem. It cut like any other plexiglass. I hand sanded the edge and need to do a little more before it looks factory. Anyway it's not all that difficult.
No that's not a crack at the top it's a finger print.
[IMG]local://upfiles/47469/3A7BFD9869BE4C6DBBFD4C41FD474EB1.jpg[/IMG]
Old 12-30-2007, 07:36 PM
Vinnie85FXWG's Avatar
Vinnie85FXWG
Vinnie85FXWG is offline
Default RE: Cut down my windshield today
You did good.
Old 12-30-2007, 07:37 PM
Dorkman's Avatar
Dorkman
Dorkman is offline
Nice job. I too would be a bit afraid of cutting a windshield. You use a fine blade to avoid chipping and splintering?
Old 12-30-2007, 07:40 PM
rjmac53's Avatar
rjmac53
rjmac53 is offline
well done
Old 12-30-2007, 07:45 PM
jad's Avatar
jad
jad is offline
No, this was a 7 tooth I beleive. For wood cutting. I just made sure the windsheild was flat at the blade while cutting. I tried sanding it with an upright belt sander. It left the edge course and wanted to melt it if I didn't keep moving. The hand sanding is the best. The finer the grit the more it gets that dark blue line that a stock cut has.
Old 12-30-2007, 08:06 PM
Rhubarb's Avatar
Rhubarb
Rhubarb is offline
You can use a jigsaw with a wood blade as well.
I used a Dremel with a side cutting blade.
Sanding I used 200 grit on an orbital and got an exact match to the factory.
Looks like you did a great job. Hardest part for me was figuring out a line I liked... well that and getting the courage to cut it.
Old 12-30-2007, 08:59 PM
mimo's Avatar
mimo
mimo is offline
Not bad, not bad at all, Nice.
Mimo.
Old 12-30-2007, 09:39 PM
wldbill's Avatar
wldbill
wldbill is offline
I've trimmed 3 windshields to fit me and my bikes using a Sears sabersaw equipped with a "fine scrolling" saw blade. The sides of the blade have been ground flat and have no teeth protruding. It's made by Lenox and picked it up at the local hardware store. Adjust your saws speed so that you don't cause melt or burn.
Old 12-30-2007, 09:49 PM
aviator's Avatar
aviator
aviator is offline
since I didn't have a band saw or a jigsaw available, I took it to a local glass shop... they cut and polished it for $20.00.
Old 12-30-2007, 11:39 PM
Bowtieman31's Avatar
Bowtieman31
Bowtieman31 is offline
I cut my 2 previous ones with a saber/jig saw. The one I just cut on my new bike, I used one of those "Roto-Zip" tools. No problems with any of them.
Quick Reply: Cut down my windshield today
