changing risers on heritage
I bought a used 05 heritage, and the previous owner installed 2 1/2" pullback risers. How difficult is it to swap out risers. I want to go back to stock risers.
What is the part# for the stock risers.
Received 1,271 Likes
Don't know what the part # is, but any local indy or HD shop can tell you. Changing is easy - remove the 4 screws holding your bars to your existing risers, remove the bars and put them on a padded cloth on top of your tank, turn front end to the right & remove the bolt holding the left riser to the top tree, turn front end to left & remove same-same bolt, install new risers, torqueing bolts to spec, install bars & riser top.
