Spark Plug Wires
Spark Plug Wires
A friend of mine gave me a brand new set of 8mm (40 ohm) spark plug wires he was going to put on his worked 2003 Road King. I still have the stock set of wires on my basically stock bike and I was wondering if there were any advantages or disadvantages to installing these on my bike.
I am also unfamiliar with how to install them on my bike.
Any feedback?
Any feedback?
RE: Spark Plug Wires
If you have a repair manual there may be a spec for resistance measured in ohms. Install should not be a big deal at all. Just remember to never pull on the wire, pull on the boot. When installing new ones there is a silicone lube you can use to ease removal in the future. You should be able to pick it up at any auto parts store.
You can check the resistance with a simple voltmeter and see what it shows on the new ones, then pull (or just disconnect at both ends and test your wire on your bike. I'm just guessing that there wont be a huge difference unless your ride has lots of miles on it. The resistance within the wire will cause the spark to be weaker the more resistance that there is. Also keep in mind that the length of the wire can affect the resistnace also. ie a longer wire will have more resistance than a shorter one. Hope this helps and good luck.
I have a set of Taylor (well known in high performance auto circles) Thundervolt 50's and they seem fine. My only reservation with changing plug wires is that on these FI bikes the plug wire is a critical piece of the puzzel. There is some sort of electrical wave that runs to the plug via the plug wire and then is returned to the ECU for some purpose or not.
i think this video explains it better...not sure though
I like high end audio...you would be amazed how much effect wiring and electrical supply has on sound quality.
Running lights and sockets on the same ring as your hi fi causes all sorts of 'noise pollution'.
Im sure picking better plug wires must have an advantage but I wonder why more focus is not given to it; I'm sure the stock wires are pretty damn basic!
Yea, I am not worried about screwing up the EFI set-up because my bike is carbeurated. I just am not sure if there will be any advantage to changing it or if I should just wait till the stock one's are shot and then replace them.
I am not too crazy about making extra work for myself.[sm=exactly.gif][sm=confused06.gif]
Putting a set of Taylor 8mm wires on my wife's bike (because she wants pink wires, that's why). Hers is EFI too.
Anyway, found them through sumax (sumax.com). According to their site their wires are compatible with all HD ignitions. They have universal kits as well as specific kits cut to fit models and years up to current. They have contact info available if you want to confirm compatibility.
Pretty sure you'll be fine.
I used to run Taylor wires on my big block truck... No issues there at all. Had thought about running a set on my Sportster as well.
ORIGINAL: harleybodei
Any feedback?
Any feedback?
just put them on!
Really? You only get 2 to 3 years out of them.
I wasn't sure how long they last but I would have thought more than that.
But thanks for the advice.
