Throttle Grip. Assembly ?
HI, Will be putting on my Iso grips later and it say's to loosen both the cable adjusters on the throttle side.When I loosen the lock nut do I turn the lock nut & adjuster down toward the front wheel to collapse the cable, or up towards the throttle. It kinda feels the same when I do it either way. Thanks for your help.And yes I did a search & got some good tips.
Thanks!!
Frank
Thanks!!
Frank
RE: Throttle Grip. Assembly ?
Frank
You collapse the adjuster to give you more slack in the cables
https://www.hdforums.com/m_77161/tm.htm
The second link in this post deals with YOUR grips...
https://www.hdforums.com/m_69241/tm.htm
Thanks TCSTD. I just found it before you posted back lol. I put in a different words forthesearch and it came up. Thanks again for the quick response an Help
Frank
Frank
you turn the adjuster down towards the front wheel to collapse >> while you have it apart go ahead and smear some grease all around the handlebar where the throttle grip rides >> this helps in a smoother throttle response
ORIGINAL: fasteddie
You'll find that the grease isn't the best to use here, it slows the action of the throttle down (drags). If you use dri slide or something of this nature, the feel and movement will be far superior to the grease... http://www.ironbraid.com/driside.html
Yes Dri Slide works great have been using it on all our dirt bikes for a few years And it was what i used on my sporty when i changed out the bars and installed grips at that time Tryit youll like it IMO
