rear turn signal upgrade
Old 12-31-2005 | 10:48 AM
q's Avatar
q
Default rear turn signal upgrade
Want to be seen when I put the brakes on. Have not rode for 20 years, but remember my decision to quit, ' outside forces beyond my control', *** hole drivers. Do not understand LED on my search of an upgrade or the suggested electronic parts of the up grade. Can I get some help here for my first upgrade. FIRST HARLEY, 2005 FLHTC, got about 600 new miles on her since purchase 11/05/05.
Old 12-31-2005 | 12:29 PM
spartns's Avatar
spartns
Default RE: rear turn signal upgrade
Welcome to the forum! You'll get a ton of good advice here. As for the lights, Harley makes a plug in adapter that turns your turn signals into brake lights. It's about $35.00. For LEDs, lots of aftermarket stuff. Kuryakin makes some good ones. Here's the link to J&P cycles.http://www.jpcycles.com Search LED tail lights and you should see 'em.
Good luck
Chris
[IMG]local://upfiles/1995/D009ADB981B14119A6E1BE8F31524406.jpg[/IMG]
Old 12-31-2005 | 12:38 PM
VetteSiNz's Avatar
VetteSiNz
Here's a good site to start with:
http://www.customdynamics.com/harley...ts_catalog.htm
Old 12-31-2005 | 12:45 PM
Grover's Avatar
Grover
Administrator Emeritus
Veteran: Marine Corp
Bought the Kyryakyn Panacea tail lihgt and turn signal light kit. Waiting to get my HD security system installed and programed to do the installation. I will let you know how it works.
Old 12-31-2005 | 01:43 PM
mtgriz's Avatar
mtgriz
I bought a Kuryakyn unit that plugs right into the system behind the battery that I'm pretty happy with. It makes the turn signals function as taillights/running lights so you have 3 lights back there instead of 1. When you apply the brakes the turn signals and taillight go into a short flashing cycle to get extra attention behind you. I don't think the HD unit works that way. Got it from Direct Parts for about 40 bux. I always felt that those cars coming up behind you while stopped at a light represent a major threat since you've got to trust those morons to be paying attention.
Old 12-31-2005 | 06:13 PM
Gunkholes's Avatar
Gunkholes
Today, rather than ride in the drizzle, I decided to install the Panacea lites on the scoot. The whole job took about 30 minutes. I am amazed at how much brighter the tail end of the bike is now. The rear turn signals acting as additional running lights make a lot of difference. And, as has been mentioned, the momentary flashing, plus the extremely bright LEDs are an attention-getter. I'd recommend this upgrade, in spite of the rather high cost. The more you can throw up in front of the cage morons the better.
Old 12-31-2005 | 09:40 PM
Edmo's Avatar
Edmo
ORIGINAL: Gunkholes
Just remember, all that is required it get a cage license is $25 and the ability to stand still long enough for the photo...
Edmo
Old 01-01-2006 | 12:58 AM
mwike's Avatar
mwike
Can you get the brake light in LED & not do the entire conversion - leave the turnsignals alone?
Old 01-01-2006 | 05:15 AM
Qball's Avatar
Qball
Biketronics makes a plug-in unit as well with a couple of features.
Old 01-01-2006 | 07:35 AM
BirchwhiteHD's Avatar
BirchwhiteHD
Stand for the photo,lol
In NH you sit for your photo,imagine how nervous i am waiting at lights for them to change
I need to upgrade my lights in the rear as well,just cant figure what to go with
Quick Reply: rear turn signal upgrade
