New pipes scraping ground-Help this Newbie
I recently had a set of Samson Big Gun 3, Street Sweepersinstalled on my "07" 1200 custom. They were installed by a professional motorcyclemechanic.
My issue is that I turned right, kind of tight on a slightly, very slightly mind you uphill grade and heard the bottom pipe scrape on the road very slightly on the underneath side near the turn-out of the pipe.
I don't feel that I laid the bike over too far on the turn. You can't see any mark or hardly even feel where it rubbed the ground.
I know the pipes are installed correctly. Does anybody have any experience with this issue. I'm unsure ifIlay it over on a turnany tighter will it rub even more? Any comments or experience with these pipes would be most helpful.
By the way, I love how they look and sound.
Please help,
fasthorse
Please help,
fasthorse
RE: Samson BG3 Street Sweepers exhaust???
looked bad azz as well with the flat spot worn into it.
thats just the way it is. my dyna did the same thing when i took corners, ground down my thunderheader and flattened it out the point where the primary tube was 50% of its normal size. its just the nature of the beast. i finally just took my thunderheader and chopped it up and rerouted the forward primary (see pic below). now i need to do something w/my outer primary on the other side as its almost ground through also. just have to deal with it. congrats on feeling comfortable enough to grind pipe in the corners.
RE: New pipes scraping ground-Help this Newbie
Will setting the pre-load higher on the rear shocks help prevent your pipes from dragging?
if you lift the back up any... it might make the difference. I am lucky my pegs grind before anything else. I think thehuggers and sports sit up alittle higher also.
ORIGINAL: fasthorse
ORIGINAL: fasthorse
