i need help with 2" tank lift
i just installed a two inch tank lift on my 07 wide glide and the triple tree hits the tank. the lift looks great so i would like to leave it but not at the cost of a big dent in my tank. i would appreciate any suggestions. thanks in advance.
RE: i need help with 2" tank lift
Have you tried loosening the rear mount bolt and see if the tank will move aft some? I oblonged my rear mount hole a little to line up the tank, thanks to HD welding the mount tab on crooked...Maybe you can get enuf clearence by oblonging the hole. My trees are close...
I have a '06 wide glide with the 2" lift and used a rat tail file on the rear holes. Had to file out about an 1/8", which gave me about 1/16" clearance between the tank the triple trees.
Ron
Ron
