Polishing rims
Polishing rims
I want to polish my fatboy rims, the entire rim. Anyone do this? The outter part would be easy but the inner I'm guessing would be a step by step sanding process.
RE: Polishing rims
I'm going to polish the outter part only, to hold me over until I just go ahead and buy the chrome disc from Harley. I was surprised they were under 500.00 a piece, that's not too bad considering the price of so of the mags wheels.
RE: Polishing rims
Hey Chris...
If you are talking about doing the actual polishing of the aluminum so as to look like chrome than you have some work ahead of you. The best place I could say to get the materials / equipment is from Eastwood Supplies. I did the aluminum rims on the wife's car and they turned out great....after 15 hours of elbow grease, and that's with having a shop setup with air tools. It will be virtually impossible to get the chromed look without the use of high speed tools.
I have some before and after pics on my home computer. I can send them to you if you want.
One other thing...if you plan on doing this with the tires off the rims than I STRONGLY suggest using Zoop Seal when you are done. This will chemically seal the aluminum to prevent it from getting dirty, spotted, soiled, stained, etc. in the future
Hope this helps,
Brian
Hope this helps,
Brian
RE: Polishing rims
fatboy there is a place on ebay that will chrome your rims for around 550 for both. just type in harley- davidson wheel and you will find them. good luck
RE: Polishing rims
If you want shine then Mike's got the right idea. If the stock Fatboy wheels still have the machining ridges in them then a simple polishing compound won't do it if you are looking for a smooth, chrome-like finish. You'd have to start by removing those marks and work everything in stages....and it is a pain and a LOT of work.
I've never seen a Fatboy rim up close so I don't know what the finish is like. I'm just assuming they are machined.
Brian
Brian
