Oil Change without bike lift
Old 11-01-2007 | 09:08 PM
sddyna's Avatar
sddyna
Default Oil Change without bike lift
I am planning on changing all the fluids soon before I put the bike away for winter but I don't have a bike lift. Anyone have a tip on how to do this without a lift or another person to hold the bike upright?
Old 11-01-2007 | 09:14 PM
Donnylee's Avatar
Donnylee
Default RE: Oil Change without bike lift
Yah- put a pan underneath it and change the oil!!!!! No lift needed!
Old 11-01-2007 | 09:21 PM
06dynablack's Avatar
06dynablack
yep you be better off without a lift for changing the fluids
Old 11-01-2007 | 09:23 PM
Lost1's Avatar
Lost1
No lift needed- just warm it up & drain it out.
YTHOG's Avatar
YTHOG
I just changed mine on my Deluxe last night. As donnylee said, NO LIFT NEEDED. I let it rest on the stand, put the pan under it and let it drain. The tricky part is the oil filter. No easy way to do that. It took exactly 3 qts of oil. Good Luck!!
mustasz's Avatar
mustasz
Exactly, and to make it clean & easy with the filter insert a lenght of aluminium cooking foil under the filter
when you change it.Mat
Old 11-01-2007 | 09:41 PM
Baeseman1's Avatar
Baeseman1
Hey mustasz, how long did it take you to polish your bike for your avitar pic??? Greats God man...
Old 11-02-2007 | 06:44 AM
oldgeezer's Avatar
oldgeezer
When you pull the derby cover to refill the primary, you'll need to put something like a short 2*6 under the side stand to get the bike more upright.
Old 11-02-2007 | 08:29 AM
Neckball's Avatar
Neckball
Just leave it on the side stand, works every time.
Old 11-02-2007 | 10:27 AM
Phrogman's Avatar
Phrogman
Well, assuming you mean all the fluids, you can pull it off with a little work.
The engine and tranny are not problem, just use mustasz's idea for foil under the filter and you're fine. I've done that since they first put the filter up front.
As for the primary, just like oldgeezer said you can prop the bike up by placing something under the kickstand, but I prefer to cut a 4x4 fence post intoblocks that will support the bike on the frame rails. That way I don't have to worry about it tipping over either way. I'd give you measurements, but every bike is different.
GittinThere
05-08-2018 09:06 AM
glcash
Touring Parts
12-28-2015 10:55 AM
CSMHOG
08-27-2013 04:17 PM
c50plus
03-05-2011 09:49 AM
Garinsr
11-21-2009 07:21 AM
Quick Reply: Oil Change without bike lift
