Notices
Differences between Dynas and Softail Standard/Night Train?
Old 11-01-2007, 12:29 PM
carpetride's Avatar
carpetride
carpetride is offline
Default RE: Differences between Dynas and Softail Standard/Night Train?
this should clear up any remaining questions you may have about softail frames http://www.patentstorm.us/patents/61...scription.html
  #62
Old 11-01-2007, 01:58 PM
uesque's Avatar
uesque
uesque is offline
Interesting article about HD chassis development while Erik Buell was working there:
http://www.badweatherbikers.com/buel...817/14773.html
"Having a national-caliber road racer behind the bars of some big cruisers resulted in some stress tests the original H-D designers likely hadn't envisioned "We'd ride those bikes, and they'd be just flexed into a pretzel," laughed Buell at the memory."
  #63
Old 11-01-2007, 02:18 PM
cadman311's Avatar
cadman311
cadman311 is offline
There go that design
  #64
Old 11-01-2007, 06:20 PM
Donny's Avatar
Donny
Donny is offline
rubber mounted bikes have the swingarm mounted to the back of the motor/trans, to keep the belt tension and alignment right. Since they can't do that with the softail, because it would totally change the geometry and look, they had to keep it solid mounted. They only balanced it, so that softail owners would'nt cry about it, when other bikes got rubber mounted to reduce vibration.
  #65
Old 11-01-2007, 06:39 PM
hdpearson13's Avatar
hdpearson13
hdpearson13 is offline
ORIGINAL: Donny
i forgot that, buti beleive yourcorrect but if iremember it does pose another problem with primary sprocket, clutchor transmision that they had to problem shoot and limits the amount of torque it can hold I beleive its around 120 but who uses that most much on a regular basis but it would be fun. I still believe the best frame from the factory was the fxrs frame. It would be cool if they brought it back for another run
  #66
Old 11-04-2007, 06:50 PM
DougsDyna's Avatar
DougsDyna
DougsDyna is offline
ORIGINAL: riskyfool
Isn't the animosity and competition supposed to be Harley vs metric?
I don't understand all this bickering about which type of Harley is the better bike when everyone already knows its the dyna. But you still shouldn't be bashing other Harleys anyway. Save that for the metrics.
Have to agree, and agree again on this comment
Dynas are the best bang for the buck, the fastest stock Harley, the best handling of the bigtwins, and probably the most fun to spent tons of money on. Baggers may have a softer ride, cause they be heavier.
DougJ
  #67
Old 11-04-2007, 11:43 PM
TowJam's Avatar
TowJam
TowJam is offline
It's not the weight - it's the air suspension. Pure heaven compared to the typical spring-over-strut.
roscoe2010
01-08-2013 06:51 PM
01ntrainultra
07-24-2012 10:45 AM
Wallaby
06-06-2010 07:46 PM
Zonian
08-04-2006 02:17 PM
berryCR
Welcome Area Only
10-26-2005 12:22 AM
Quick Reply: Differences between Dynas and Softail Standard/Night Train?
